What is this??
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
Had some work done on my truck and found this under the hood. It is about 24" long, looks like a thermocouple. Long end has SET900WF stamped on metal, then copper wire and at the other end is a magnetic piece of metal. Any ideas what it is.
ACDII
Oct 21, 2021
666
412
Illinois
It's a mechanics pick up tool. Guess the mechanic forgot to retrieve it before closing the hood.
Fordtech86
L3200
Aug 7, 2018
4,947
5,846
Pineville,LA
Yes its a flexible magnet
Also as a tech, we appreciate and remember customers that return tools that get away 😉
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
Yep looks like a homemade mag pick up. Probably used to extract the plugs, F150 plugs sit deep so it would help to have a mag with reach. Called them and will drop it off. Thanks for the input.
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
2,965
When I first glanced at it I thought you might want to check under the hood more often ,, just sayin
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
Funny thing is that the hood is open when it is in the garage, have it on a battery tender. I bet I had it open a dozen times since the work was done. It must have been tucked away on the side because the magnet attached to the lift cylinder and I saw this weird wire that looked out of place.
Stmar
B2650HSDC
May 23, 2017
908
42
Buffalo, Wyoming
Returned it and you would have thought it was a $100 tool instead of $10, in other words they were appreciative. Guess it is the thought and effort that counts.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
422
297
Lake Almanor, Ca
so what you are saying is…that the mechanic needs a pick up tool for his pick up tool?
