L4310 steering cylinder removal?
halfbean
M9540
Mar 17, 2017
Slocum, Tx
My 4310 steering cylinder is leaking around the piston on end closest to the seat. I was wondering if there is an easy way to remove it? It looks like the radiator may have to be removed to get the pin out of one end. Has anyone done this?
Thanks
Hal
5,696
The pin drops out the bottom, there is a keeper plate with 2 bolts holding the pin in place.
halfbean
M9540
Mar 17, 2017
Slocum, Tx
According to the diagram and feeling up in there, the pin that is on end of steering cylinder rod has a piece of round bar welded on top so it won't come out the bottom. It is right underneath the radiator and there isn't enough room to lift the pin up. At least that is what I'm seeing. I was just wondering if there was a way to do it without unbolting radiator?
CaveCreekRay
Jul 11, 2014
2,631
99
Cave Creek, AZ
hb,
Can you unbolt the radiator while still keeping the hoses on (wet) and simply lift it up enough to clear the pin?
