Dead battery
p020554
BX2360, MMM 60, Front snow blade 60, Disc harrow 60
Dec 17, 2011
11
Iowa City, Iowa
Can I jump start my BX2360 with my car? Ran out of fuel yesterday and jumped off without turning off the ignition (yes I know pretty stupid).
johnsayen
117
42
There’s probably a section in your operators manual showing the steps after running out of fuel, as I think you might need to bleed the system. It’s usually not as simple as adding fuel and turning it over. I realize that doesn’t answer your car question.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
You will probably need to bleed the air from your fuel system to get it running again. There is a specific procedure on your owner manual ot do this. It will require turning the engine over for starting. You can either charge your dead battery or jump from a car. A diesel engine takes a lot of power to turn over. Jumper cables may not provide enough power to do this. Charging may be your best option.
2,457
TO bleed the air, fill tank - get a good battery hooked up or jumped via your car, TURN the key until you hear the mechanical pump "buzz" - hold the key for at least 30 seconds - sometimes it may take 60 seconds. The pump will push all the air back to the tank and fill your line with fuel.
You can hear the pump change pitch when it starts pushing fuel!
4,793
fill tank, key on for 30 seconds,off for 30 seconds,then start. may run a wee bit rough for a minute or two..BTDT...
