aquaforce
L245DT FEL, JD450 Track loader, 5' scrape blade&mower, 5x10 trailer, Dump truck
Apr 22, 2009
757
Stockbridge, Ga. USA
Today was the dreaded time for a battery in the Kubota. These batteries cost way too much but with cold weather coming on there is no way I want to have a no start on a bad freezing day. I bumped up the crank amps too. It should do very well for a few years now.
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
12
Western Ky
So you put a "what?" in a "what?"
aquaforce
Apr 22, 2009
757
My little orange tractor is an L175. The battery was an 06 year 24 series DL and it had 600 CCA. It did well I guess as it lasted 6 years.
The batt I installed was a 34 series with 940 CCA. It won't be working hard at all to keep the tractor well supplied so it should last longer too; guess we shall see. :)
Apogee
B6100, B7100, B8200, B9200, G4200, L175, L35
Jan 22, 2012
518
Tacoma, WA
Aqua will hit the key and a HUGE spark will come from the starter and burn up his new paint job....
:eek:
bcbull378
Sep 6, 2011
579
27
Ventura Ca
I sub soiled ( ripped ) the safflower field today 6 acers today getting ready for the rain . The big field will require the D-6 and a larger ripper. The cattle arnt qiut done with that field .
Yoda 7030
1990 M7030. Front loader, back hoe, snowblower, discer, 3 furrow plough,
Oct 14, 2012
9
Walters Falls, Ontario
Well, unfortunatly I had to put the doors back on the cab. Getting a little cool and quite windy these days. Then I spread a little gravel and smoothed out the driveway and parking area at home before going to work
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
440
31
Atascadero
85 degrees here :cool:
TripleR
Sep 16, 2011
1,911
SE Missouri
Did a little bush hogging and spread some rock on one of my roads; too muddy to do much else, maybe tomorrow.
pmhowe
L4240, Ford 8N, Kioti CK 2610
Jun 23, 2012
117
Banner Elk NC
It was a beautiful day here in Colorado, but we had a little snow last week. It was a good incentive to start getting firewood in. I spent yesterday cutting dead fir, spruce, and lodgepole pine (the three most common wood species where I live). Today, I used the Kubota to bring the wood in for splitting. I've attached a couple of pictures. Fall here is a glorious time of year, whether it is crisp or warm.
Just for laughs, I also included a picture of a visitor we had a year or so ago.
TripleR
Sep 16, 2011
1,911
SE Missouri
Beautiful pictures.
JOE LOW
b2620 FEL BH RM59
Jun 19, 2012
11
PORT C
Well today I changed out the hydraulic and filters ,steering then spent a couple hours on the backhoe digging a garden plot for next year.
A first for me doing the tranny oils and stuff ...............wasn't so bad at all and saved a shipload of cash
RD Gray
BX2200 LA211 Loader 5' rear blade Woods PHD ph35
Oct 31, 2012
42
Luray, Virginia
Well,I went out and tried out my post hole digger. Dug twenty holes about 2 foot deep with a 12" auger. I had to enlarge them by hand some to 16" and some to 18". I 'll finish them tomorrow. It didn't go to bad I don't reckon for my first adventure with a post hole digger.
hodge
Nov 19, 2010
2,890
428
Love, VA
Like others, I serviced my tractor today. New changed the engine oil, filter, fuel filter, and hydraulic filter, and checked the steering box. Then, I did some driveway work with the back blade.
