Looking for the size of the 2 bolts that is on the front of the B2650 ROPS half way up to keep it tight from rattling. I picked up a M8 1.25 x 25 mm yesterday but was too small
Mine take a standard 3/8-16 NC bolt. Fits perfectly. I'd like to find a nice sized knob fitted on the bolt for hand tightening and loosening purposes.Looking for the size of the 2 bolts that is on the front of the B2650 ROPS half way up to keep it tight from rattling. I picked up a M8 1.25 x 25 mm yesterday but was too small
The belt covers on LandPride finish mowers are 3/8" thread with approx 2 1/2" knob. They will screw right in.Mine take a standard 3/8-16 NC bolt. Fits perfectly. I'd like to find a nice sized knob fitted on the bolt for hand tightening and loosening purposes.
Regards,
david
Thanks whitetiger! I'll check them out. They should work perfectly!The belt covers on LandPride finish mowers are 3/8" thread with approx 2 1/2" knob. They will screw right in.
6feettogo, that's interesting! Maybe they've used both types of bolts. After your post, I had to go check mine and they're definitely a standard 3/8-16 bolt size. Here's a couple of pics of the difference in the threads and the M1.25 pitch gauge next to the standard 3/8" bolt:This is what I ordered from Home Depot and they fit just fine.
Everbilt M10-1.25 x 40 mm Class 8.8 Zinc Plated Hex Bolt
Mine was a 2019 model. Not sure what yours is. I think I got the size from looking up the ones that Kubota uses (the ones with the knobs). If you go through these threads it show another person using these.
ROPS Threaded Hole
Uhm, there is no gotcha. As stated, O.P. has a B2650 and that was where the thread/conversation were pertaining to! Current prouct below: So BX (knob) B standard or deluxe current product (nothing) L standard (jamb bolt) grand (nothing) MX (nothing) Pat Pat I think firemail meant gotcha in...www.orangetractortalks.com
Thanks for those "threads". It appears the thread pitch and bolt size is anything but standard amongst the models and even within the same models. The M10-1.5 pitch mentioned is getting closer to my 3/8-16 thread but but still not even close. I even tried it again with an M10-1.5 tap. A definite no go. So now I feel pretty safe stating mine is a 3/8-16 NC thread and I'll look for those knobs that whitetiger mentioned.Plus I would have thought that all the bolts used on Kubota would be metric.
A lot of the USA market only items on a Kubota are SAE. BX and RTV units have always used SAE wheel bolts, BX uses several SAE joints on linkages. Some units have USA only ROPS with SAE bolts in them.Plus I would have thought that all the bolts used on Kubota would be metric.
Thanks for the info will go see if I can get oneMine take a standard 3/8-16 NC bolt. Fits perfectly. I'd like to find a nice sized knob fitted on the bolt for hand tightening and loosening purposes.
Regards,
david
