BX 23STLB reverse was slow now fixed
Dover
bx23tlb
Jan 29, 2020
Napanee, ontario, canada
I have a BX23S , since getting it 2 years ago, fwd was normal but reverse was slow and had no power. To back up a slight incline, I had to put it into low range (turtle). This week it eventually stopped moving in reverse completely. Drove it forward to the garage, then the reverse worked in a slow crawl. Looking under the tractor, I found the problem.
The shaft coming from the forward/reverse pedals toward the rear of the tractor has a link, just above the hydrostatic oil filter. The nut had fallen off. I removed the oil filter to get access, added two nuts to the end of the link replaced the filter and it now has a reverse speed I had not seen since I bought it. Attached are two pics.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the OTT forum Dover.
I am glad that you found out what the problem was and was able to fix it.
It makes perfect sense that would be the problem once you see it. I guess that goes with all the other nuts to be checked for proper tightness when delivered.
propuckstopper
GR2010, BX2380
Jan 10, 2018
37
While you are at it, check the under seat spring nuts and the throttle lever nut. There are a few threads on this forum discussing those very issues. Like tis one:
https://www.orangetractortalks.com/forums/showthread.php?t=39380
rotaryjohn
BX2380, FEL, LPBoxBlade, Piranha Tooth Bar
May 6, 2018
14
Ila, GA
Any chance anyone knows what
Any chance anyone knows what size nut this is. That is the problem with mine and I want to get the nut beforehand.
2,902
1,370
It would be 5/16" 24 TPI
4,957
It would be 5/16" 24 TPS
Dang - - you've forgotten more than most of us will ever know.....
Awesome... (y) I know you and a few others here have paid their dues...
My hat's off to you....🤠 :)
kilmurraybx
Bx23s
Nov 1, 2021
Tannersville
Hi Dover
Will I need to take off backhoe to do this job, I could not find the connection.
Thanks
Brendan
GiuseppeC
Kubota BX23S
Jun 18, 2024
Southern AZ
I have a BX23S with the same issue. I saw your post and pictures and went out to my tractor and discovered the same situation. Re-attached linkage with two nuts as you dis but made second nut a locking nut. Hope not to have this issue again. Thanks for your post.
