the bx does’t have a cable, the lever is directly connected to the the valve shaft, try spaying Blaster on the shaft where it goes into the housing. The mechanism is simple, its sort of like turning on a faucet valve to pressurize a cylinder that engages the pto clutch.
You have not used the PTO in a while?
Store the machine outside?
I haven't used the PTO lever since I finished mowing in September. I always store the tractor in the garage.
Do I need to remove the tire to get to where the shaft goes into the housing?
