Air goes where fuel won't. We run into this all the time at work, so much so that we often test with air instead of doing hydrostatic testing. And, I've used helium with a detector, or N2 with H2 tracer gas and detector to test for leaks as well.Looked at the fuel lines in the parts manual and WOW! That little contraption under the tractor is a baby fuel tank with 5 tentacles. It is item #100 in the attached picture. The big fuel tank has 4 lines going into it. Would all these lines need to be replaced to rule out an air leak in the fuel system? If yes, I may just settle for starting the tractor in 10 seconds as long as I can start it in cold weather
I don't see any actual fuel leaking anywhere and once the tractor starts, it runs well at any RPM. I have run it for about 3 hours in the month I have owned it without doing any work.
OR... I might trade it in for a new 2501 HST with a loader since I definitely got the tractor bug.
So, you might not see a fuel leak, but air may be getting into the system.
Again, if it were me, I'd start replacing fuel lines that are subject to heat and being disturbed. So, I would replace from the injector pump back to the filters, and then from the filters back to the fuel pump. My logic is that stuff that's not disturbed or subject to heat are often stuck to the barb, and need a good twist to break them loose to remove. This indicates that the joint is sealed as long as I don't disturb it.
If this doesn't solve the problem, then it might be time to assess and decide if going further is worth the effort. I would probably take a look at the injectors. If the tractor sat for long periods, they might need a good cleaning. If you have a diesel shop close, it might be worth pulling the injectors and taking them to be cleaned.
Personally, I'd probably work on it until it starts to my satisfaction. I guess I may be a little OCD or something.
