what oil to use in mower deck?
hockeystewey
2017 BX1880 w FEL, 54"MMM, 2019 BX2816 50 " snowblower
Dec 12, 2017
114
NY
my mower deck RCK54-23BX..says to use 90w oil in the gear box.... is that what everyone uses? I did a quick search most seems to be marine lower unit ...or is 80w acceptable for the unit?
thanks!!!!
SDT
multiple and various
Apr 15, 2018
3,107
957
SE, IN
thanks!!!!
80W90 GL-5 will be fine.
No need for lower unit oil.
SDT
4,292
SDT
SDT's advice is always solid.
I honestly pulled mine off the shelf to check my own oil and GL # to make sure I had the correct stuff.....
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Agree, 80w90 or 90W.
My new F3990 leaks some lube and it has only 50 hours on it. Real hard to understand why something this new leaks, but I'm using Mobil syn 90W. If it leaks any higher, will look into 90w140
LobsterClaw207
BX2680 with FEL and 60" MMM, rear PTO snowblower, 4' box blade, pallet forks
Jun 2, 2019
Gray, Maine
Do you need a special tool to check/change/fill the oil on these things? I poked around and wasn't sure how I'd check it.
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
To change remove both plugs on the side turn it up on its side and let it run dry. Replace the bottom plug and fill from the top plug until it starts running out the bottom.
LobsterClaw207
Jun 2, 2019
Gray, Maine
Awesome thanks!
hockeystewey
Dec 12, 2017
114
NY
I tipped it up on back wheels....and unscrewed the filler screw to drain it out. used the side as a vent. worked like a champ!
