Kubota b7100 HST will not stop when releasing pedal
My Kubota1
Port St Lucie, FL
My Kubota B7100 HST does not stop when releasing the pedal when going forward, I have to push the reverse pedal to make it stop. In reverse it stops as soon as the pedal is released. Is there an adjustment for the forward issue?
Thank you
SDT
multiple and various
Apr 15, 2018
3,084
926
SE, IN
Thank you
Could be adjustment, damper or a broken pedal return spring.
The pedal return spring on my 1993 B1750 failed about a month ago. The replacement springs have a coiled piece of rubber inside to prevent vibration of the spring and subsequent metal fatigue failure.
Not uncommon.
SDT
