Loader valve lock wont lock on L2501.
Tornado
792
254
usa
Brand new L2501 owner here. Machine has just 8 hours on it right now. Ive encountered only 1 issue so far that Ive noticed that I consider a factory or manufacturer fault, and thankfully its mostly a non issue I think - The loader valve lock. Picture is attached of the valve lock. Once I got the tractor home and began to use it and really look it over with a fine tooth comb I noticed that the lock valve would only go about halfway then stop, and I could tell it was hitting something. No amount of forcing would get it beyond half way. With the lock stuck halfway, it is enough to prevent the loader from going up and down, but not from operating the bucket itself up and down (side to side movement of the stick is still possible) With the lock halfway its also easy to bump it or for it to move back to unlocked. How often will I ever use this really? Probably never honestly, so Ive mostly ignored the issue, though it does kind of annoy me to have something not function right on a brand new piece of equipment, so I decided this weekend to remove the whole plastic cover and investigate what the issue actually was.
Once I got the cover off, I was able to see the locking mechanism is very basic - a Pin simply slides through 2 holes in the lever mechanism to prevent the lever from moving. I quickly realized what the problem was as well. The pin is hitting the rim of the 2nd hole it is supposed to go through, as it isnt drilled just right for smooth operation. I was able to take a hammer and tap it all the way through, but its super tight when you do this and you can not physically unlock it again without using a hammer and screw driver to tap the pin back out. No amount of jiggling or moving the stick around helps. I also got a pair of pliers and tried manipulating the 2 little lever plates to jiggle the pin in/out - it just wont work without being forced in and out with a hammer. Its just machined poorly and its visible to the eye. I also put greese in the pin hole to lube the area up good, and that didn't really help. You can not lock it with the lever, you have to beat the actual pin with a hammer to get it to move.
Im starting to ramble but you guys get the drift of the issue I hope. I tried to get a drill bit in there but its a tough little spot to drill, and you hit the pin which is soldered into the mechanism so its hard to really drill the hole out to allow free movement. I finally gave up and put the cover back on. I didn't want to keep banging and forcing things and end up bending something. I cant think of any scenario where id ever really use the lock anyways, so I sorta resigned myself to accepting the flaw for now. I'm curious if others have had a similar issue. Im also curious how this passed QA given the issue was immediately apparent the first time I tried to use the lock, and was clearly an issue from assembly from what I see. Any suggestions on an easy fix would be appreciated but I dont think anything will work short of being able to drill the holes out just a tad to allow the pin to easily pass through, and from my memory of it, it was welded in place
SidecarFlip
Banned
557
Have them on both my M's, never used either.
nbryan
Jan 3, 2019
1,284
817
Hadashville, Manitoba, Canada
Mine was quite sticky at first on my new B2650 in 2017. It has worked itself in now, bit still takes a little jiggling to lock. Sounds like yours has more issues than being sticky.
Sent from my Moto G (5) Plus using Tapatalk
Tornado
792
254
usa
Yea, unfortunately, mine is not just sticky. You can not move the lever to locked position without striking the pin itself with a hammer, which requires the whole plastic cover to be off. With the cover on you can not fully lock the loader. It is a clear hit when it stops, and no amount of muscle will move it. I think my only option is to somehow drill the holes out a little, but that seems more trouble than its worth I think, given If i recall correctly a lot of the elements I would need to disassemble to do the drill work are welded in place.
NewtoOrange
L2501
Mar 1, 2017
50
Pleasant Plains, Il. USA
I only use mine when I have the loader off, probably no particular reason other than to not activate the system since nothing is connected to the lines. If it something you think should be fixed I myself would take it to the dealer just because it is under warranty. You paid enough for the thing so let them figure it out. My biggest complaint was no right side handle bar on the fender. Messicks did fine for that but sometimes it makes me wonder about engineers.
