L2250 front axle rebuild
Wideopen38
21
SUMMERVILLE
I just got a Kubota l2250 4x4 in good shape but the front axle was messed up. I just put all new bearnings, seals,gears,ring and pinion. I have put it all together the problem it there is one is when you lock the 4x4 in the drive shaft locks in like it should but both wheels turn instead of locking it like the driveshaft. I didn't crank it up and the front end is jack up.When I spin it by hand it make some clicking noise like gears.Should it be on the ground and running to work right? I'm new to this so I don't know all the right words or if I am making since.
5,513
With it up in the air and out of 4wd what happens to the untouched wheel if you spin the other?
With it up in the air and in 4wd what happens to the unspun wheel if you spin the other?
5,513
Do you have the drive shaft exposed so you can see the couplings?
Sound like you have one that is stripped.
Drive out roll pin (060) and remove bolt (090) and slide the 2 halves of the propeller shaft cover (040, 070) together and inspect the couplings (020) on both ends.
You might need to drive one of the roll pins (030) out and remove the shaft to inspect.
Wideopen38
21
SUMMERVILLE
Ok I took the coupling loose from the pinion gear shaft, when I lock it in 4-wheel drive the driveshaft will not turn when I take it out of 4 wheel drive the drive shaft will turn. When I hook the driveshaft back up to the pinion gear shaht I turned wheels in the wheels turning opposite direction but the pinion shaft going into the coupler does not move but I hear gears skipping it sounds like it's no engaging somewhere in the front axle I guess. When it's locked in four wheel drive should the wheels be able to turn when it's up in the air?
2,688
1,192
With the front drive engaged or locked in, you should be able to turn one front tire by hand and the other should also be turning only in the opposite direction.
5,513
That sounds perfectly normal, as the transmission is engaged to the rear wheels so you shouldn't be able to turn the shaft.
I think you get the misconception that something in the front axle locks in to put it in 4wd, nothing in the front axle changes between 2wd and 4wd, and the propeller shaft turns both in 2wd and 4wd.
It's only the rear at the transmission that changes.
Now if you turn the pinion and your getting a bad clicking, knocking, or grinding that's not good, but a gear whirr or slight chatter of gears is somewhat normal.
Yes, like whitetiger said, they will turn in opposite directions.
Wideopen38
21
SUMMERVILLE
Yes I thought something in the front axle should have locked in when I put it in 4-wheel drive. So I think I'm okay,I'm going to give it a shot tomorrow thank you all very much for helping me out so much.
2,688
1,192
Either 80/90 gear oil, SUDT or synthetic 75/140 gear oil
