I have stripped the threads on the rear axle housing transmission drain plug and hole on my ZD326. I can see in the hole that there appear to be good threads beyond the stripped portion in the hole. My plan is to install a longer bolt in place of the stripped plug, but the bolt I tried to install will not screw beyond the damaged portion of the hole. The bolt I am trying to install has 12mm x 1.25 threads. I am not positive that they are the correct threads. Before I try to clear the threads with a tap, I need to confirm what the existing threads are.
Can anyone tell me what those threads are?
Also, does anyone have a different suggestion for repair? I have heard of expansion plugs that can be installed in place of damaged drain plugs, but do not know what might be available.
