Why not,
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
please explain...
All of mine are one side longer vs. the other. Over lap is over lap, doesn't matter where it is.
To the OP, your "question" is a bit hard to understand. There should be a "short" measurement with the implement up at the top and another (long) measurement with it lowered on the ground. I guess 26.5" is the "long" measurement?
I think the over lap is 6" but I could be mistaken....
Not so fast my feathered friend!
Look at it this way........
Making this up on the fly here........
A 24" pipe slides into another 24" pipe......when it hit bottom, the shortest length it can be is............you guessed it .....24"!!!!
Cut 3" of the larger pipe.......minimum length once inside ..........24" still !!!!!!
If the short (sliding inside) is not cut then cutting the outside helps = zero!
best way to do this is to have the implement on the ground - take a measuring tape and do the math at the longest point - centerline to centerline is best! THEN collapse the shaft to it's shortest point.....
then raise the implement all the way up, past where you might never go!!! AND measure again!
AS long as the top is greater than the shortest length - everything is fine!
BUT if the compaction needs to be shorter, cut BOTH pieces - SO the INSIDE cannot bottom out nor can the OUTSIDE bottom out!
YOU still need overlap at the bottom - but it will overlap more as it rises.
he can show you what I am trying to explain!!!
https://www.youtube.com/watch?v=0vBFJcvs5SE
