Hi, folks. First timer on the forums.
I've killed the hydraulics on my 'Bota L4400H using the BH90 to dig a septic system. I fear I got the system's hydraulics far too hot. The top boom cylinder even got too hot to touch along with the lines.
Backhoe stopped suddenly and now I've got a lovely whining/grinding/spinning noise coming from the pump area at engine shut down.
I've got no hydraulics to the front bucket or backhoe at all, even after an overnight cool down. At least the trans is working so after using a winch to get everything up, I was able to get it into the barn.
I've researched my shop service manual (great investment), user manual and used the Kubota.com Illustrated parts site to find both the pump as well as the exploded parts showing all the components. (T1150-36403 pump assy)
I'm here asking for advice on two things:
1. After checking the relief valve settings and everything else I know of that may have accidentally and/or purposely engaged disabling the hydraulics, is there anything else (levers, buttons, knobs, chants, spells, animal sacrifices) that I should look at? The no steering leads me to believe I've truly killed the pump.
2. If I'm to rebuild the pump -barring any galling or breakage inside the housing- are there any known "gotchas" I should be aware of that are not listed within the service manual itself? Any tips or tricks some of you might have?
One last thing, I recently changed the hydraulic fluid (did not do a flush)after a broken line replacement as well as both filters so contamination should not be a factor. Levels were correct so no cavitation that I'm aware of. Heat is my only suspect.
TIA
Cpt. Jera
TIA
Cpt. Jera
