L4150 dt
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
I need to source some 8"x20" rims for the front of a 1985 L4150DT. The ones current installed are 8x15 and have a ribbed tire on them.
I've contacted Wold in Iowa. They have a mass produced 8x20 that has 5 3/4" backspacing for $112/ea....but I'm not sure if that is the correct backspacing for the tractor. They can build a custom wheel for $285 each to my specs....but I don't know what the spec are....but once I get the front axle back together, I'm sure I could figure it out. But...that might be some time.
Thanks!
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
In case anybody finds this in the search. I received this info from Kubota.
<<The front/rear gear ratio for the L4150DT is 1.497 for the standard drive train. If the drive train has the optional 17 tooth gear, the front/rear gear ratio is 1.585. He will want to select a tire size that will provide a 1% to 5% positive slippage, See attached work sheet to calculate a 1% to 5% positive slippage
Regards,
Technical Support Team>>
5,406
Ribbed tires on a DT something isn't adding up??? :confused:
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
The previous owner installed them. When I picked it up to work on, I was :eek: The rears were 21.5L x 16.1 Firestone turfs.
It was a bad combo....I'll get it straightened out. I scored a used pair 13.6x28 R1's mounted, with the centers from Tucker Tire. Now on the prowl for a suitable front....and I need to buy some rims. :mad:
5,406
I do believe that is the front drive gear, I also think it was just an odd way of saying if it has 4wd it has a 17 tooth gear, as there is no other options for gearing.
Now considering that you have the 13.6-28 rears you need 8.3-20 for the front.
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
8.3-20...yep. But first I want to measure the RC of the 13.6-28. But yes, I need something about 105 RC for the front.
Thanks!
Eves
L4150DT TLB
Feb 12, 2021
GA
Regards,
Great info. Thx. My current set on the L4150DT is goodyear industrial sure grip 16.8-28 rear and 10.5-20 front. They appear to be the original tires. According the the calculations the slippage is greater than 5% with no drive issues that i am aware of. I cant seem to find a new tire set to get below 5%. The closest i can get is frontRC 113" and rear 156". Will this set up cause any issues?
