I've got a 1987 G5200 diesel lawn tractor. Got run out of fuel. Won't start (no smoke from exhaust, just turns over until battery is done).
I've bled the fuel lines up to the injector pump. When I turn the key with the bleed screw out on the injector pump fuel squirts out.
Trying to figure out, is there some trick to bleeding the injector lines (other than loosening them and turning over the engine)?
Several online "how to" say to use decompression lever and turn engine over for 10-15 seconds. I cannot seem to find a decompression lever on this engine and the (brand new) battery will only turn over the (brand new) starter for few seconds.
Any tips and/or tricks?
Doug
Doug
