Hodge stabilizers WAHOO !!
tcartpilot
BX2370 Loader Rotary Mower
Jun 28, 2015
12
Philomath,OR
Just a quick shout out to Mr. Hodge and his stabilizers. Well built and great service. Took twice as long to get the old turnbuckles off as it did to get the new ones installed. I am very pleased! :D:D
Tooljunkie
May 13, 2014
4,150
32
Nice. Would like a set for my lil tractor, shipping makes it prohibitive.
I like fabricating, may try bulding my own.some day. After my hundreds of other projects.
Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
Feb 16, 2015
1,022
9
Lovells, Mi
I bought the hodge stabilizers and later added a quick hitch. The quick hitch eliminates some of the need for the stabilizers because you don't have to adjust the turnbuckles every time you attach an implement. However, if you use the 3 point hitch a lot,the stabilizers make it easy to swing the implement to the right or left. If I angle my rear blade 30 degrees I need to swing the blade to the side to extend past the wheel.
Fro65
L3301HST, LA525, BH77, LP tiller, LP grader box, LP blade, BX2380
Dec 30, 2014
220
NorthEast Indiana
I would love a set of these for my L3301 if that is an option. Where does one go about getting a set? I found a Hodges farm equipment but it doesn't appear to be the right place.
69 SS
2015 L3901 HST,with Canopy,LA 525 FEL with SSQA bucket
Sep 26, 2015
103
21
Ft. Inn sc
The factory ones are what sealed the deal when I bought my new 3901. Dealer swapped them out. I still want a quick hitch. So much easier when you need to offset an implement to one side,or really stabilize that subsoiler . Yours look really heavy duty compared to the factory ones
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I made a set for my 3301. It took 5 dollars material and a couple hours labor. Helps to have a machine shop:D
hodge
Nov 19, 2010
2,870
387
Love, VA
Anyone interested it talking about getting a set can private message me. I am still building them, but at a reduced schedule. I am glad to converse with interested folks.
2,303
I love my Hodge Stabilizers. The PO had broken my originals several times and they had been welded so many times that they were no longer adjustable. The Hodge Stabilizers are so quick & easy to adjust & will probably outlast the rest of the tractor. They're one of they few products I've bought in my life that I can recommend with absolute confidence & no reservations whatsoever.
olthumpa
L275
May 25, 2011
1,501
Maine
Unequivocal second! :)
2,289
I'm trying to understand how you get a finite adjustment with these things?
what you cannot see - the larger piece slides OVER the smaller piece......the pin simply locks the two together. So you have almost infinite hole ratios to select from!
rut3556
L2250, TG1860
Oct 23, 2015
115
NH, USA
Gotcha..... Thanks for the clarification.
2,303
The hole spacing on the inner & outer parts is also different, giving a pretty fine adjustment.
hodge
Nov 19, 2010
2,870
387
Love, VA
Stabilizers are not meant to be adjusted banjo-tight. Tightening turnbuckles when the arms are down is a good way to stretch the stabilizer when the arms are raised. The stabilizers don't mount at the same point as the lift arm, so there is a slight variance in the geometry of the two. Because of that, it is advisable, and sufficient, for the stabilizer to hold the implement stationary, but not tight. With telescoping stabilizers, the hole in the tubes is spaced differently than the holes in the rod. Because of that, the increment of adjustment is less than the actual spacing of the hole. On the stabilizers that I build, the increment is about 3/16". When both stabilizers are adjusted properly, there is about 1/2"-3/4" of movement from side to side. That isn't much, and it certainly is enough that the implement is stationary.
Fro65
Dec 30, 2014
220
NorthEast Indiana
PM sent...I think...I'm not real good with computers:eek:
Sammy3700
Feb 20, 2012
431
36
Red Springs, NC
Burt, so do you have any pictures of them on your L3700? If so will you please post them or text them to me.
Reklues
Kubota L3800 HST,Woods BB60,woods 72"RB,LP 42"forks HD carry all,1k boom pole
Apr 23, 2014
10
Indiana
I got this set from Hodge a little while back.....and they are over the top QUALITY !!!!!!
