Thank you. I knew it looked correct and there is really no other place to attach the cleats.Yep some are designed on the inside and some on the outside.
I have no mid PTO. But I still should check to see if there is a place to prevent the lowering of the arms unintentional.When you used the term "check chains" I thought of another use. In the case where you have a belly mower that is raised and lowered via linkage to the three-point system, there might be the time you have lowered the arms, unintentionally, with the control lever and they may go too low, as almost on ground. There may be attachment place on your tractor for chains to keep the arms from dropping too far.
