Serial number on older Kubota tractor
genecenfl
bartow fl
I was under the impression that the serial number was stamped on body near the clutch pedal.
I found this number there: B6100 IE 11189.
I sent an e-mail to Kubota and they replied:
"The number you sent is not a registered Kubota number"
Is there another number on this tractor somewhere? This tractor belonged to a friend of mine who has passed away and hi s mother wants to sell it.
I am trying to find out when it was manufactured.
Thanks!!!!!!
5,612
What you seek is very hard to get!
Most information on those older tractors is hit or miss.
That is the right serial# It's a B6100E model (E means 2wd) and serial# is 11189.
If the tractor wasn't registered, which is very common on the older tractors, Kubota Corp. will not be able to provide you with any information.
It was made somewhere between 1978 - 1984, year does not matter too terribly to most tractor owners, parts are based on model not year.
maj_primate
B6100 HST
Jan 6, 2013
31
Summerfield Florida
It appears your tractor was manufactured in 1978 according to tractordatainfo.com. A total of 8823 copies of the 6100 E were manufactured between 1976-1984. I have a 6100 HSTE which were built between 1981-1986. 1902 copies of that model. The web site quoted has many more Kubota models listed, as well as other manufacturers. Tom
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
maj_primate, could you please tell how you located this information, as I'm trying to find info about my B7100 HST tractor also? THKS
flynavy
May 1, 2014
95
Laurel Springs, NJ
Opps Me Bad...Sorry I should ave read more carefully as you did show your source (tractordatainfo.com) I missed it the first read...Sorry
Arlin Oilfield
Westlock
It is likely a Gray Market Tractor in which case Kubota does not seem to want anything to do with those.
I have an L1802DT and I tried talking to a dealer for some parts.
They do not recognize that it is even a Kubota tractor.
Arlin Oilfield
coachgeo
Nov 16, 2012
2,460
34
Southern OH
Little off topic...... just went to this site and interestingly.. they do not list the L235 models or the L2350 models.
5,612
There is actually a ton of Kubota tractor models not listed! ;)
Also the info on some of it is wrong, they do not have the info for the B7100HST-D's right because there was many more models made after the late 80's. and the serial #'s are the same or they quoted them wrong.
coachgeo
Nov 16, 2012
2,460
34
Southern OH
It appears that site may be operated by SSBtractor. It is from the Same IP.
Since there is no contact page on tractordatainfo guess corrections could be sent to SSB?
