First post and I'm looking for advice ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A few weeks ago I bought an L2550 3 cylinder tractor that was in overall pretty good condition. However it had one problem that helped me knock the price down some. It has a pretty good oil leak from somewhere on the front of the engine. It was really hard to get any view of where it might be coming from. I did hot pressure wash the tractor to remove as much grease and oil as I could and that helped a little.
My first thought was from the location and from what I could see when it was running that the leak was likely at the front of the oil pan gasket. I ordered a new pan gasket and yesterday I removed the oil pan. Using my CSI skills (or lack there of) I'm thinking it probably wasn't the oil pan gasket. At least there wasn't any smoking gun indicating where the leak was.
While lying under the tractor and using a bright flash light I saw indications that the leak could be coming from the front crankshaft seal.
My questions are: can the front seal be removed without removing the full gear case cover? The service manual (just purchased new from Messick's) doesn't give a lot of detail about the front seal. If it can be removed from the outside that would be great. With my luck however I'm betting I have to remove the gear case cover.
Assuming I have to remove the gear case cover, is there a way to keep the crank from turning while removing the nut holding the pulley on?
Any tips or suggestions would be appreciated.
Thanks!
Brad
Thanks!
Brad
