Zd331will not start
belviderejim
L3838.L4740,RTV1100,ZD331
Sep 22, 2021
Richmond, VA
Our zd 331 will not turn over. When we by pass the brake switch the mower will start . But we must disconnect the bypass wire in order to keep it running once we try to move forward. Is another switch the actual problem?
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
406
194
Randolph county N.C.
I have owned my ZD323 since 2009. I have changed out the brake safety switch 3 times, I think it gets gummed up with debris kicked up from front of mower deck. As a temporary work around I hold the key in the start position and cycle the brake pedal until it starts. I have blown out switch with compressed air and sprayed with contact cleaner also.
