I made the mount using 10ga steel. I welded 3 braces on the back, notched out for the ROP's and drilled holes to mount. I mounted it to the 4 existing ROP's bolts. The box is an ammo box mounted with 4 bolts and rubber washers. I made the washers from a piece of horse stall mat and a 1 1/4 hole saw. I re-positioned the reflective triangle bracket. I lined the box with outdoor carpet. All the parts were painted using Kubota grey paint. I used scraps so the only cost was the stainless hardware and paint.
