Using Kubota Spray Paint
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
This seems like the right section for my question...
I've got a couple older implements on the farm that I'd like to make look a little better. Some of them have some paint on them and it's chipping off in places and showing surface rust. Do I need to remove all the old paint getting the item down to metal, or can I just use a brillo pad to scratch up the paint before spraying it with the Kubota spray paint?
Thanks!
2,553
Thanks!
Get a couple of "tools" for your drill and grinder.
I wire brush - a sanding flapper with rough grits and some good primer and after a couple of hours of drill work - it will hold paint for years.;)
https://www.amazon.com/Forney-72740...95191129&sr=8-3&keywords=wire+wheel+for+drill
https://www.amazon.com/DEWALT-DAFE1...5191155&sr=8-2&keywords=flapper+sanding+wheel
IF you have a 4" grinder ....this works wonders.
https://www.amazon.com/Angle-Grinde...191155&sr=8-13&keywords=flapper+sanding+wheel
hodge
Nov 19, 2010
2,903
450
Love, VA
You want to get the loose paint and rust off, and scuff up the old paint. I would use an etching primer- Rustoleum makes it in a rattle can, and it's available at Lowe's, Home Depot, Walmart (automotive section), Tractor Supply, etc.
Which color are you using- orange or grey? The Kubota brand paint is good, but it takes a while to cure- like a couple of days. Rustoleum, and a few others, are making Kubota Orange paint, which cures faster. Or, you can use Rustoleum Chevrolet orange engine paint, which is very, very close.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
Thanks!! I'm always looking for more toys... I mean tools.
I've got a DeWalt 20v cut off tool, hammer drill, and impact driver.
gk527
Kubota B2650
Apr 6, 2017
140
Central Kentucky
I'll be using the actual Kubota orange paint from the dealer. It's Orange II for newer.
John T
2017 BX23S
May 5, 2017
816
296
under a rock
Wire brush /sandpaper /flap wheel as mentioned above...
But I always give it a good wipe down with an acetone rag
Seems to help make the paint stick.
bearskinner
Sep 1, 2014
926
241
N. Idaho
As an alternate paint source, I go to the local Tractor store ( North 40 in the PNW) and use Van Sickle industrial Tractor paint. The Kubota color match is great, although it does need to cure overnight.
5,585
I use a wire brush that fits in one of those Harbor Freight 4 1/2" throw away grinders, and get all the loose stuff off....paint, rust, etc. Doesn't need to be to bare metal. Then use this surface prep. You can buy in it qts. for twice the price you get a gallon.
I put it in a spritz spray bottle and spray a light coating on. Let it dry for a day. Wipe if of and it's ready for paint.
It even etches the paint that you didn't need to remove.
Brush similar to this: http://www.globalindustrial.com/p/t...mpaignId=T9F&gclid=CJH9usKF_NMCFUO5wAod1dcAyg
https://www.amazon.com/Ospho-Skyco-Surface-Prep/dp/B000C02B3W
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
To answer your question, one has to answer other questions......
!. How much do you want to spend?
2. How much ambition you have?
3. How much time would be involved along with the size of the job?
4. How particular are you?
5. Will you be happy with the outcome when you've finished?
All the answers others have provided are fine and will work.
BUT, YOU need to please yourself first
If I were doing this job I'd first sandblast the parts to bare metal and then fill any voids with body filler. Use a good primer, like "Zinc Chromate",then begin to paint.
Long and short of it.....there really isn't one good answer to that question.
Best of Luck;)
5,585
Thanks!
The part I highlighted in red gives me an indication of the original poster's intention.
Flynavy, if you're going to use body filler in the painting process for older farm implements...I'm left without words. Have fun!!
Lencho
B7100hst
Jan 21, 2017
415
87
NM
I use the same method as D2Cat - an angle grinder fitted with a wire brush. It grinds the rust away leaving a surface ready for prime and paint. The only down side is the wire bristles can shoot out - the last mower deck I did left me feeling like I'd messed with a porcupine.
Tooljunkie
May 13, 2014
4,150
Yes, those wires are nasty, usually dont feel them going in.the carhartts slow down the wires considerably.
I like my air die grinder with rolock sanding discs and scotchbrite buffers. I dont prime for rust paint. Just slather it on.
6,596
I started picking up heavier duty wire brushes for my die grinder. The one I have now, has been mated to my heavy duty die grinder for 4 months. And still has all the bristles :D
Ridger
L3940 HST
Nov 26, 2014
144
North LA
I recently repainted some of my implements mainly to get familiar with the HF purple HPLV paint sprayer. Not an expensive paint sprayer but worked well for what I intended to do. I used a wire brush and a wire wheel on my drill to knock off the loose rust and then I used a paint brush and coated it with a product I read about called Corroseal. It is a rust converter that turns the rust black. After it cured for a day or so, I painted over it with Rustoleum Farm Implement Kubota Orange paint. They turned out pretty good for implements.
https://www.amazon.com/Corroseal-82...UTF8&qid=1495401490&sr=8-2&keywords=corroseal
