Transmission Hydraulic hose removal.
RickyJudy
2020 L4060 Kubota Tractor
Feb 12, 2024
Kentucky
I have a 2020 Kubota L4060, and I broke off my transmission filter. To replace the broken bracket, I will need to disconnect the metal line. How is that do?
RickyJudy
5,908
Really need to know what variant your working on.
And which exact filter as some have 2:
Here is a DT variant of the main hydraulic filter:
Pull 2 bolts and remove pipe.
1,267
In that version above once the bolts are removed and the rubber hose is disconnected then the hard pipe will just pull out of the filter housing.
