Transmission/Hydraulic fluid fill area
Cribbster
L3000DT
May 29, 2015
Williston,SC,USA
I just acquired a Kubota L3000DT with a LB402 loader needing to know where to add transmission/hydraulic fluid and how to check level? I have no manual that came with tractor. Thanks, Cribbster
coachgeo
Nov 16, 2012
2,460
35
Southern OH
I just acquired a Kubota L3000DT with a LB402 loader .... I have no manual that came with tractor. Thanks, Cribbster
try Kubotabooks.com. There are some free manuals there
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
77
Rocky Face, Georgia
Right behind the shifter should be a plug and vent tube that screws out. Down on the left side of the trans housing you should have a round site glass. It has a white back ground and if the fluid is nice and clean it's very hard to see the level.
I'll warn you ahead of time, the L3000 is picky about how you check the fluid. It needs to be sitting on very level ground to get a accurate reading. Hope this helps.
