towing a Kubota with HST
Oldstuff
L 3400
Jun 1, 2022
26
Missouri
I am a new owner of a 2009 Kubota L 3400 HST. It is operatong just fine now but a HST is new to me. So, my question is that in case I have a breakdown (tractor quits running) in the future I will not do the wrong thing. Parts of my property are in the timbered area and it would be impossible to get a trailer to the location would it hurt anything is all selectors were in nuetral to tow it with another tractor to the trailer?
Thanks- Oldstuff
bmblank
Mar 4, 2015
653
285
Cadillac, MI
Putting the range selector in neutral should disconnect the wheels from any of the hydraulics. It'd probably be a good idea to make sure it's not in 4wd.
With any luck you'll never need to tow it. I can't imagine it'd be a fun job.
rc51stierhoff
2,796
What would be the recommendation to do with the loader if you could not run the engine and loader down and you need to tow? Is dropping/undocking the loader the only option if you need to tow it?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,711
1,451
WestTn/NoMs
It would be easier to jack or winch the bucket up, then relieve the pressure with the loader valve. Unless a hose is ruptured, the loader will stay in place for at least a couple of hours. Don't forget you need hydraulic pressure to remove the loader, unless you have additional lifting equipment.
RalphVa
738
320
Charlottesville
My neighbor towed my JD 4010 from my back yard to the driveway and towed the lemony JD 1025R from the back hill up to the carriage house. Just put both tractors' HSTs in "N". He towed with a strap that ran underneath the FEL to hold it up out of the way. Think both had the brush hogs dragging.
4,700
loader is easy...
connect comealong between bucket and ROPS, place loader control to 'lift' (need helper or strap...., use comealong to raise the bucket. Add a second strap as a safety, in case the comealong breaks.If it does, go buy a lottery ticket cause the odd of it breaking are astronomical !
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
183
137
Westford, Massachusetts
shelkol.com
loader is easy...
This sounds like the voice of experience LOL
4,700
well it wasn't 'LOL' back then....
after that I made wooden U-shaped 'supports' to block the bucket up about a foot off the ground ,'transport' height.
towing backwards is GREAT until you see you're going AWAY from the house......:(
5,226
Sounds like a lost deer hunter !
