BT3101
L3130 GST, FEL, TaylorWay BH W/Subfr Rotary Cutter, Pallet Forks, Grapple Bucket
Pretty excited about this purchased made during Amazon Prime Days for roughly $1350. Received it 4 or 5 working days later. I have a lot of field encroachment I need to deal with.
Mounted it up today but need to buy some smaller quick couplers. As with the grapple bucket I bought from them, the fittings are 1".
Came in a steel crate that I was able to save for re-purpose. The grapple came in same style crate. It does come laying down 90 degrees from where it needs to be to attach to the tractor and if you want to save the crate, it must come out the top in this image. The top is bolted and everything else is welded.
I was able to lift it and rotate at the same time and save the crate. Otherwise, I may have needed to cut the crate apart.
The jaw opening is about 8". The adds say you can grasp a 6" tree. The teeth are 1" thick. Overall, they used some thick steel. 3000psi cylinder.
For $300 more, you can buy a blocking bar to keep trees and shrubs from rotating back on the tractor. I have a CNC plasma table and plan to make something similar for mine. I have a lot of honeysuckle bush, and it gets wide. I want to make my push bar full width.
