Tire size and cost
ranger danger
Kubota M6060, MEB 802A tactically quiet generator
Jun 11, 2017
310
293
East of Placerville Ca
I recently picked up a M7030DTN. This is a 4X4 tractor. The tires on the rear are getting pretty bad so I'm looking to replace them. The size on there now is 16.9x24. Is there a more available size that would save me money in the long run even if I had to change wheels?
Cathy Liebchen
KUBOTA L3901, MX5800, MULE PRO FX, MULE PRO FXT
16.9 x 24 is a readily available and common size tire
ranger danger
Jun 11, 2017
310
293
Thanks, I got confused:eek:!! My other tractor is an M4000 2X4. It has 18.4-16.1 tires. These are the ones I will be needing.
ranger danger
Jun 11, 2017
310
293
Boy I really screwed this post up!!:eek:
The tires I will be needing first are the 18.4-16.1. I have spent a bit of time on searching this. What I found is this size tends to be quite a bit more expensive then many other sizes I have had to deal with ($675 each!!). My question was if anyone could suggest an alternate size that does not cost quite so much but would still fit the wheel. I have also read that, due to the price of this size, it could actually be cheaper to get new (used) wheels as well and still be cheaper. Other tires in a comparable size run around $350 each.
200 MPH, Thanks for the search suggestion, I would never have thought of that.
200mph
Mar 3, 2017
1,228
61
PA
This is slightly less expensive. I did buy tires from this place in the last 6 months and was a great transaction and the tires were recently molded.
https://www.tires4that.com/itemdetail/48D890
If you know the wheel mounting dimensions for your existing wheels you might be able to find comparable tires mounted on wheels through "Wholegoods". This is the sales department at your local Kubota dealer and is NOT the sales department.
If tractor is 4x4 you'll need to pay attention to overall tire diameter.
Sorry I can't be of more assistance.
Good luck
Added in Edit:
Check out Nebraska tire. They have a listing for $349
https://www.nebraskatire.com/agriculture
It's shown in the block titled: Compact Tractor Tires Discounted R1 and G1 Lug
ranger danger
Jun 11, 2017
310
293
Good luck
Added in Edit:
Thank you sir, that's very helpful. Ill check and see what the shipping costs are.
