i have a 2003 l3130 with 380 hours. if you turn the steering wheel the front tires wont turn unless you turn the wheel quick.then it turns but go a little ways and it does the same thing. i lifted the front end off the ground and you can turn the wheels freely by hand. if you turn the wheel when its in the air it turns good. could it be the cyl. bypassing or the pump.
