Slime
Bruck
Kubota
Nov 14, 2025
Connecticut
I had a front tire unexpectedly go down on me the other day. I couldn't find anyone to fix it on a Sunday so I waited. I did a bit of research on this forum and found it interesting that Slime is kind of an accepted thing. Growing up I remember "fix a flat" and my dad saying that they will never work on your tire again if you use it. I figured this was the same.
Anyway....I used it today and the tire is good as new. I was very pleased. Good thing too. I had to dig a trench to have electrical run from my new garage to my shed.
2,895
I have used it by the gallons.... works well. I am sure those that fix tires may not like the mess it creates after the fact.
old and tired
L2800 HST; 2005; R4
I've used it a couple of times.... after a while one tire kept loosing air and I brought it to the tire guy, he was busy so I took the time to clean the rim for him (he really appreciated it...) and since I put the slime in there, I felt obligated to do the dirty work....
Another tire, front tire on my lawn mower (I've told this story here before)... Mid afternoon I noticed it was over pressurized and showing it's aging cracks in the side wall. Decided I'll deal with this later since I had guest staying overnight (one in our old camper).
Next morning at breakfast, he ask WTF was the big explosion last night. No one in the house heard a thing. Later I walked down to the lawn mower and that front tire did indeed explode!!! Looked like a movie set from Ghostbusters, green slime all over the place....
Bruck
Kubota
Nov 14, 2025
Connecticut
That's a pretty wild story bro.
Kennyd4110
Vendor Member
Sep 7, 2013
1,418
743
Westminster, MD
www.boltonhooks.com
I personally think these are better options:
8,734
I got slime in two out of 4 tires on my tractor. What was interesting was the rear tire had popped off the bead when it lost air. So I first had to get the tire to take air and get it back on the bead first. The pull the valve stem.
While I was pumping slime into the tire, It popped off the bead again 🤪🤪🤪🤪
It made pumping the slime into the tire much easier 😂🤣😂🤣😂🤣
I put about 3/4 of a bottle in the back tire. Got it back on the bead again, and taking air. Aired up the tire and then worked the tractor for a while.
It was a fight, but once aired up, it's held good for over a year now 😎😎😎
Botamon
Mar 26, 2018
409
778
Winnemucca, Nevada
I use Slime but only in the tires on my ATV and side by side. Seems like every plant in the desert has thorns sticking out and those thorns are stiff enough to penetrate the thin ATV/UTV tires and cause slow leaks. Slime does a great job of stopping the leaks.
