Shifting a Kubota L2000DT (L225DT)
allantg
Moncton, New Brunswick, Canada
Built in the mid 70's this grey market does not have a synchronized transmission. Since purchasing, I have never tried to shift on the fly as I have no experience double clutching, etc. Also, have never used the tractor on other that a few of the slower (lower gears). Used to a car where you really can't start out in fifth gear. Have tried to read as much as possible but there seems to be some conflicting info. Regardless of the gear I think I need to use, must I always start from a standing stop and once moving if I want to change gears, must I always stop first. Anyone out there with a similar model that could advise me what you do?? Thanks.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
11
Richmond Va
You are correct on this. The older tractors are NOT shift on the fly and you will grind out gears and wear out your clutch alot faster that way. So from a dead stand still select a speed and direction, relase the clutch and go.
daniel.ray77
1976 Kubota L225DT
Nov 16, 2009
141
Salt Lake City, Utah
I have an L225DT and when i'm in high range, i frequently shift thru the gears while moving albeit very gingerly! I have "learned"where the shift points are. But honestly, you can put the tractor in whatever gear you want (1st thru 8th), let out the clutch and go! Starting out in 8th gear takes a bit of clutching but nothing that will wear it out unless you're pulling a huge load around all the time. Be careful not to clash the gears like the warnings state. Always have the tractor at a complete stop when shifting between forward and reverse.
Deneh
Zen Noh ZL2000FD
Dec 2, 2010
42
Herlong, Calif
I own a L2000DT and have shifted it on the fly once or twice but would not recommend doing it as it just tears it up. Better to have a tractor that works or pay the price later :D
J252
L345DT & L3400DT
Feb 4, 2011
Vancouver
The gears are straight cut to provide maximum torque and power transfer. If you want to get into 'speed shifting' your L-2000, keep my email handy. I ship gray market Kubota transmission parts worldwide!!
For what its worth, and despite the warning and recommendations pasted on that great big label on the dash, I shifted our old L345 on the fly for most of its life and never had a problem. The key to shifting without much (if any) grind at all is timing the shift. How fast you move the lever between the gear and at what rpm. I found the most effective way to up shift was to single (not double) clutch and shift the gear relatively quick quickly (with a flick of the wrist) all the while letting off the foot throttle a bit to allow the RPM to drop. When done right its slides right into the next gear like your favorite compact car.
For us it seemed like a necessity. When driving on the road (especially with some load or a trailer and especially in a hilly area), starting in 8th gear was just murder on the clutch. I would start in 6th and then shift up to 7th and then 8th. Rolling downshifts to climb the hills (8th to 7th) took even more practice to execute smoothly.
Obviously is it safest to the transmission to only shift at a complete standstill. It's your tractor, and your risk. I feel that it 'can' be done safely.
bayou4004x4
14
wi
question ? i have a older kubota,in the 70's,L22DT,4X4 24hp diesel,can you tell me if this is a gray market tractor ? whats the difference ? plus if u see my thread ned help....
marc123
1975 Kubota L225DT
Feb 13, 2015
mckinney,Texas,USA
WANTED Im looking for a entire tractor or front end or just one front end inner axle housing for a Kubota 1975 L225DT 4x4
bobby 870-284-1748
Tomcat
B7000 4WD, RS1(?) rototiller, Konik 125 ATV
Nov 19, 2014
557
Thailand
For a better chance at a response, you might try the classifieds section;)
