Definitely didn't want to start a debate! Was just wondering what others did. Personally I tend to run around 2000 for most tasks, and adjust as necessary depending on how the tractor responds.
RPM's is a broad "range" question - so simply asking or saying what RPM should an engine be placed in to do a job is dependent on TOO many variables.
If we look at gasoline mowers - 95% of the time the throttle is placed in a "notch" that is almost 100% WOT - very rarely do we move a lawn mowers throttle once we start the cutting. Choke it and go!!
On a chainsaw - fire it up, let it idle a bit and then pull the trigger - again WTF open - max throttle! (Yeah I know, towards the end of a cut we might slow down - I do it all the time)
On cars - we vary the throttle to achieve a certain speed - Never hitting WOT. Well - rarely!
Now tractors are different gas and diesels engines - point noted, HOWEVER - the engine DESIGN are different across the board - the number associated with RPM is useless in a debate!
BUT the RPM percentage wise is what is more important - As a BX owner - the MAX WOT is 3300-3400 and I have been there many times, but there is a nice a fuzzy feeling between 2800-3000 - I find that 2200 is almost useless - so at 3000 RPM's I am using about 90% of the max RPM.
On the L2501 as mentioned several times in this thread the WOT is something like 2200 - Much larger engine than BX - and tuned down a bit to stay under the magic 26 hp EPA rating ..... so running around at 1900 RPM is about 85% of WOT.
SO the RPM's are meaning less - the real question should be - what % of WOT do you run your machine???
We cannot compare old style NON EPA engines to newer DPF and REGEN engines - they are on another level all together and cannot be "treated" in the same discussion due to the ability to run the engine cleanly.
AND the true answer is - where every it seems to work best for YOU !!!! (without babying it!)
I do find that those parts that are hydraulic in nature do not work well down near idle - and sometimes they can be too "fast" at WOT (swinging a boom/pivot on a hoe) - there is a "nice" range - but again the notion that one specific percent of WOT is best for all is ............ well - that can be debated all you wish - but again it simply boils down to the mindset of the operator!
And we know a mindset is terrible thing, once a notion is planted! Was I talking about diesels?
