reverse air flow
Jacquelyn
Oct 23, 2010
Deep River, Iowa
Does anyone know how to change the reverse air flow so that the heat from the engine will come back to the heat houser? It looks like all the warm air will go out the front of the tractor and not back on the driver when it gets cold. We have a new 2660
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
That is how most Kubotas are designed. It also blows the dust and dirt out the front instead of at the operator.
I guarantee that it is much better to put on another coat in winter than have the engine heat flow all over you in the summer.
Jacquelyn
Oct 23, 2010
Deep River, Iowa
Very true, but does any one have any ideas on how to use that engine heat on our sub-zero Iowa days? I really don't want to buy an expensive cab and we already have a heat houser (protective covering). Do you think it will keep us warm?
bikerdib
L4701 with FEL, BH92 backhoe
Oct 5, 2010
210
14
Wallis, Texas
If you really have a problem dealing with the cold (can't put on enough layers), put a lighter plug on your tractor and get some of the electric clothing designed for motorcycling. I ride motorcycles and I live near Houston so it never gets cold enough that I need the heated clothing but I do know it works.
Or if the heated clothing is too expensive for you, do what I've done on a few occasions when it was really cold (at least to us from down here in the south); get some of the self activated heat packets sold at most outdoor sporting goods shops then put a couple of them in the inside pockets of your jacket. They put off heat for about 4 to 6 hours.
Mingy
L3010 backhoe FEL, B2300, M9000
Jul 27, 2010
Ontario
I live in Canada, so I know all about cold. I dress very warmly (Sorel boots, snowmobile mitts, balaclava and ski googles) when clearing snow. I'd be careful about engine heat. Besides the potential for smell, etc., there could be a hazard from exhaust depending on how your exhaust pipe is routed. My 2 small Kubotas blow exhaust at wheel height. My big one exhausts straight up.
If cold is a major issue, many auto parts places sell supplemental heaters based on heated coolant. Its probably an easy install.
