Replacing transmission oil in L2600DT with FEL
luketratts
L2600DT FEL
Jul 26, 2016
35
Gold Coast, Australia
Hey All
Quick question, I am replacing trans oil, I have the WSM so following that is pretty straight forward ( pull plugs, clean strainer, put plugs back in and fill with UDT, the only thing is the WSM doesn't reference the FEL.
If I just follow the WSM the oil in the 6 rams and all the lines on the FEL won't be replaced, is this common to not replace the oil in the rams or do I need to drain the Rams and lines then bleed afterward?
Sorry if been asked a million times previously but I had a bit of a search and couldn't find anything explaining what needs doing.
redmaher
253
US
Retract all the rams that you can. I wouldn't drain the rams a little old fluid is fine. Also being a hydraulic system they are self priming. I.E. if you replace a ram or line you do not have to prime the system.
Sent from my LG-H901 using Tapatalk
6,407
No you don't need to worry about the little bit of fluid in the rams and lines, and yes it is a rather small amount in the grand scheme of things. ;)
tthorkil
M9540HDC12 / LX2610HSDC / ZD1011-48 / Bobcat S250
Jan 1, 2011
309
79
Bagley, MN, United States
Since most hydraulic cylinders on the tractor are double acting, doesn't retracting the cylinders just 'move' fluid from one end of the cylinder to the other?
RaptorDuner
L3301
May 25, 2015
Randle
Being retracted, the rod displaces more fluid than if it is extended. Manufacturers account for the fluid that doesn't get replaced at service when calculating filter size and service interval.
