I have a 2001 M9000DTC has no power anywhere I think it's is a slow blow 50amp fuse but I can't not find it. Any help would be appreciated I'm not very good with electrical
I will check there but I had battery out didn't see it thanksI found mine buried behind the battery on my BX23S. Knowing Kubota, they probably hid yours there also. Took me over 2 hours to look for it, and even the dealer didn't know where it was hidden.
Thanks I have WSM trying to find it in there.Kubota M6800S Workshop Manual (Page 100 of 638) | ManualsLib
www.manualslib.com
I believe the link above will show you (poorly) where the fuse box is located. If not, it is the workshop manual for the M9000, so the info should be in there.
