Does anyone know the diameter of the crankshaft where the rear main seals on a d1105. I put a reground crankshaft in the block and the rear main seal has approximately a 1/16th of an inch gap between the crank and the seal. I sent the old crank back so I can not make a comparison. This engine uses the same crank as d1005, v1305, v1505 wg1005 and wg1605. The crank that I have measures 72.05mm. Thanks for your help.
