Plastic roof repair on b3030
jcmiller77
Kubota B3030
Nov 5, 2022
36
I had the opportunity to buy a b3030 with a cab and it has a couple of good breaks in the roof at the front. I used epoxy to seal up the cracks, I was thinking about using RV roof tap to cover above the seam to give the roof some extra protection. I wanted to see what you all thought about that idea?
thanks for your feedback.
5,842
did you drill small holes at the end of every crack ?
use the proper 'epoxy', based upon what that roof is made from
then add a layer of 'drywall tape mesh' or similar and more proper epoxy
if done right, it'll be a LOT stronger than the original shell.
5,181
Drilling holes at the end of every crack is called "stop drilling", and is widely used on aircraft, to stop crack growth.
number two
B3030HSDC L2501HST
Mar 26, 2021
380
179
Northern Lower Michigan
I haven't broken mine yet but I'll be watching!
My garage queen still looks good,except I dimpled a fender two years ago-bummer
Sure to need this info going forward.
jcmiller77
Kubota B3030
Nov 5, 2022
36
Thanks to you all!!
Moose7060
Oct 14, 2023
827
2,243
bc
If you are not handy with fiberglass repair, then this will work.
