Perplexed
vernon1957
Kubota bx2370 , Massey Ferguson 1526 , Husqvarna Z560
May 5, 2023
Hello everone , I am new to this site . I have been having a problem with my BX2370 which is used mainly for mowing and pulling small loads . This tractor is a 2015 year with 200 + hours . I will try to describe the issue as best as possible . When on level ground , up hill or down hill everything is as normal . When crossing a hill with left side downhill all is well . Tilt to right side downhill and it begins to shudder to the point of concern . It feels as if something is binding . The tractor does not have to be in motion , in gear , mower running or anything else , just sitting still with engine running at any speed . Any help would be greatly appreciated .
JimDeL
Aug 31, 2022
295
311
Austintown, Ohio
Fuel starvation. The fuel tank is on the right side, and the outlet may be partially plugged. Also, check the fuel filter that's under the right side, just before the fuel pump. It may be clogged, or have water in it.
xrocketengineer
Nov 14, 2020
750
650
Merritt Island, Florida
Check the bars that stick out from the engine sides (red arrow) to prevent the engine torque from breaking the engine mounts. The second picture is the left one on my tractor with a nice gap to the chassis. The third is the right one right next to the chassis frame. When the tractor is inclined to the right, the bar is in contact with chassis and transmits the engine vibration. The lower the RPM the worst it feels. The dealer would not fix it, it is normal. Maybe loosening the engine mounts and centering the engine in the chassis might solve it.
vernon1957
May 5, 2023
Sounds like good advice . It is not used very often as you can tell by the hours . May be a little while before I can get to it , but will be sure to check those as soon as possible .
vernon1957
May 5, 2023
View attachment 101816 View attachment 101817
Thanks for the info. Will check as soon as possible . I had thought it may be a broken engine mount , but they seemed fine , did not know about the bars . Will check soon . Thanks again
vernon1957
May 5, 2023
Thanks to all who replied . Compound knowledge and experience is invaluable . xrocketengineer you nailed it . Sometimes we overlook the simple things , even with years of expeirence . Thanks again to all and have a wonderful and blessed day .
