I fired my B8200HST up today and used it very lightly. I mostly let it idle. In total it was less than an hour. I mounted, moved and unmounted my tiller and mounted my rear blade. I also rode it around the yard for 5 minutes. In between these activities it idled.
I had just replaced the hyrdraulic fluid the night before last and this was the first time I ran it (I don't think this is related).
About 6 hours later I went down to the garage (normally the tractor lives outside) and noticed about a teaspoon of clear, oily water underneath it. With some snooping around with a flashlight I could see that the liquid was coming from the tube (edit: breather pipe 15261-05510) that is connected to the top of the valve cover (edit: cylinder head cover 15532-14540).
Please tell me what's going on. How concerned should I be? I got the tractor back in May and its probably been doing this the whole time. I vaguely recall seeing this before when it was parked in the garage months ago, but this time the floor was freshly cleaned and I was paying attention because I'd just changed my UTF.
In another thread you may see that I also use a bit of coolant. I rarely use the tractor for more than a couple hours at a time and maybe 1-4 times a month so far. I've probably added distilled water 4 or 5 times.
If you need more information, let me know. I can take and post pictures of whatever is required as well.
