odd failure, hydralic oil leaking thorough starter engine
se-User
L175 1978
Aug 2, 2022
sweden
I have an L175 since 20years, 3000h, working as it should, but now i have a odd hydralic oil leak through the starter engine.
Can't see where that oil should come from. Gearbox is not overfilled, everything works as it should.
Read something about a "Relief valve" in hydralic system for L185 do i have the same " Relief valve" on my L175? if so where is it located?
/thanks
woodman55
L6060HSTC, RTV 1100
May 15, 2022
939
738
canada
Clean and degrease the starter and the area around it very well. Then run the tractor and verify where the oil is coming from. I doubt the oil is coming out of the starter.
Kenonf
B7100 hst, l4200dt,b2920
Oct 22, 2019
42
Florida
The oil Pressure switch is on the same side as your starter, on my d750 when it started to leak it looked as if it was coming from the starter. if it is the oil switch get Kubota, don't waste money of after market like I did.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Is the starter at the low point in the bell housing? A seal or Welch plug may have failed in the front of the transmission, and that’s the only outlet. There should be a jiggle valve or drain in the bottom of the bell housing that may be plugged.
se-User
L175 1978
Aug 2, 2022
sweden
Thanx for answering, and yes, it is no doubt, oil is comming from the starter engine, post some pics in separat post
se-User
L175 1978
Aug 2, 2022
sweden
thanx, it's not engine oil leaking, its hydralic oil. As said, read something about a "relife valve" but i can't find any (don't know where it is supoose to be
se-User
L175 1978
Aug 2, 2022
sweden
Thanx, i think you are right, i find a video on youtube,
i think my problem is as discibed in video, starts at 2minutes, some sort of ball bering seal that has failure. (lower axle, PTO-shaft)
Big big, problem, ouch, seammes like the tractor has to be splitet, argh..
se-User
L175 1978
Aug 2, 2022
sweden
Pictures, hard to se, but ini middle of starter engine theres a hole, leaking oil... tried to open up a whole in chassie, oils is coiming out there..
woodman55
L6060HSTC, RTV 1100
May 15, 2022
939
738
canada
Well on the plus side, other than the oil leak, it looks like a nice tractor. With that much oil in the bell housing, I am surprised it even moves. Have a good look at the clutch disk, I am thinking it is ruined from all the oil.
se-User
L175 1978
Aug 2, 2022
sweden
True, clutch i spoiled, new one will be installed when fixing the leak, biggest problem is to find one able to help fix this.
thanks all.
