I have never owned or used any of this equipment so please don't judge my question too harshly. I'm getting my brand new L3560 delivered in two weeks. Also getting an RCR-1860 rotary cutter. This one has the clutch. Debated a lot about shear-bolt vs. clutch but this is what was available so that's what I got. Interesting thing I found out during my research is both the clutch and shear bolt drivelines attach to the gearbox the same way - a 1/2" bolt thru the driveshaft yolk and gearbox shaft. The bolts are the same size but the shear type uses a grade 2, and the clutch type uses a grade 8. I have also read where folks suggest using a grade 5 (in place of the grade 2) to prevent snapping so many bolts. So my question is this; Could I put a grade 5 bolt in this location on my clutch driveshaft and have that be a 'fail-safe' backup in case the clutch isn't adjusted properly or gets locked up? Is this a truly bad idea? Am I the only one to think of this?
