ME5700/M5700 rattle!
wrsni
Northern Ireland
Just acquired an ME5700 with LA1002 front loader.
It hasn't had an easy life and there's a few things need doing to it. Against that, it came at a very good price so there's money in reserve for parts, all filters looked pretty fresh and were genuine Kubota, and the loader is as tight as the day it left the factory. So although we've been able to put it straight to work I hope and trust there's an even better tractor in there.
The one thing that bothers me is a distinct rattle when you stop it. It's not at tick over, it's not at start up, it just happens with what seems like the final few stutters of the engine when it's stopping.
On one hand I'm minded that it may be perfectly normal like clutch plates settling as the hydraulic pressure dies or some such, on the other hand if it's another issue I need to address I'd like to be at it as soon as possible. I must stress than once the tractor is running, even at tick over, there is no noise.
So can someone with a similar tractor advise me whether there's does it or not.
It's ME5700 with 12 speed transmission and hydraulic shuttle.
Thank you.
9,118
Usually when it comes to figuring out rattles, a second person comes in handy. Usually I'll have someone shut down the unit to try and mimick symptoms. Then the other person works there way around the unit looking for the source.
Could be the exhaust, three point hitch, D-rings, loose motor mounts, ect.....
