dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Hello,
Thanks to anyone who can help. I recently purchased a 2003 M9000 cab tractor with 789 certifiable hours. The tractor sat outside confiscated by the DEA for 7 1/2 years. It runs out very well but I bought the tractor before I found out about the apparent chronic A/C issues. When purchased, the compressor would run but the air was not very cool so I thought it may just need a charge. Per my local Kubota dealer (who deals mainly in B and L series units) I changed the expansion valve and dryer. I have access to a recovery system so I changed the parts, pulled a vacuum for two hours, and recharged the system with the recommended 2.5xxx pounds or 134. The tractor cools very well now but the high side pressure climbs until reaching 450 psi where the compressor drops out. Spraying the smallest amount or compressed air across the condenser keep the high side pressure between 300 - 350 which seems high to me. Note: I removed the radiator and condenser and made certain the fins (cooling area) is clean and unobstructed. The low side pressure seems good at 35-40 psi.
The condenser is about 3" from the radiator so I tried sealing the gap with pipe insulation but is made no difference. Does anyone know of a "recall"/upgrade to fix this problem? It is terrible that Kubota would produce a cab tractor with such a weak A/C system. While on the topic, does anyone know of a high velocity cabin fan to replace the slow turning factory unit?
Thanks for any help,
David Cochran
David Cochran
