M7060 Wanting LED Work Lights
Txphantom
M7060
Apr 18, 2021
La Grange, TX
I have a M7060 that I’m wanting to convert the work lights to LED. Has anyone just replaced the OEM bulbs with LED or was the whole assembly needed to be replaced. I’ve seen replacement assemblies for $70 each with plug-n-play connections at tiger lights.com I’ve read where the LED get hot I’m wondering if the whole assembly may need to be replaced as the new lights have built in heat sinks. Any help would be appreciated. Thanks, Phantom
Roadworthy
L2501 HST
Aug 17, 2019
1,647
526
Benton City, WA
If you can find a LED bulb to replace an existing bulb it will usually generate less heat than the incandescent. A work light is generally a low wattage light so there should be no issue. If the replacement units have heat sinks they may be more powerful than the original or have more functionality such as adding spot or flood lights.
SDT
multiple and various
Apr 15, 2018
3,266
1,062
SE, IN
New M4 tractors and probably new 7060s (no, not certain) have LED work lights as standard equipment.
Most likely, these are bolt on replacements for the older Halogen work lights. Again, not certain.
They will not be inexpensive.
SDT
Txphantom
M7060
Apr 18, 2021
La Grange, TX
Thank you sir for your information. I’ll do a little more investigation on the new lights to see what if any options they may have.
Phantom
Txphantom
M7060
Apr 18, 2021
La Grange, TX
SDT
Thank you sir, I’ll check with my local dealer to see what the new models have for work lights and will report back.
Phantom
Popgadget
L6060
Mar 11, 2020
42
17
PA
I have the Tiger Light LED work lights on my L6060 and am very happy with them. I also changed the head light and side light bulbs to LED.
SDT
Apr 15, 2018
3,266
1,062
SE, IN
Can you provide information about the LED replacement bulbs you used to replace the incandescent head and side light bulbs on your L6060?
SDT
