M4900 lift arm repair
Papavillars
M4900
Aug 17, 2014
Fairfield,tx
Working on my m4900 lift arm rod. Heard a clink , now no tension. How do i access. The inside portion? Thru the rear by 3 point shaft?
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,200
128
Coyote Flats,Texas
Re: M4900 lift arm repIr
Only way I know to access inside of rockshaft housing is by removing RS housing from trans/diff case.
6,405
You do know that you can lift the arms without any resistance right?
It only puts pressure on it when it rises.
6,405
NIW
My perception by OP stating "loose" is the 3 pt control lever is loose. Maybe my perception is incorrect?
Your right, now that I re-read it, it could go both ways. :confused:
