Lx2963 not connecting
Looymoose
Kubota 2610 snowblower lx2963
Jan 6, 2022
I have the lx2963 snowblower the shaft on the undercarriage and shaft on the snowblower are about 2in apart! I already adjusted the shaft on the snowblower to furthest setting that is where I have my 2in left? Can I adjust the undercarriage somehow?
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
Have you flipped the level to connect the coupler? The black round bar on top of the K-connect.
Donystoy
Dec 10, 2013
566
217
Binbrook, Ontario
Is this a new install? I have the same setup and have no issues. This shaft is telescoping and should extend far enough to slide on to the tractor spline. The spring loaded coupling can be a pita but doable.
