Hi, new to the forums here. I just got a new LX2610SU with dealer installed cruise control. I tried to set the cruise control to use for mowing using this sequence.
1. Set engine RPM to have PTO at 540.
2. Accelerate to desired speed with the treadle pedal.
3. Push down on the cruise control lever. (located below the steering wheel, just next to the parking brake lever)
This does not work on my tractor. It will either not engage cruise at all or will cruise very slowly. Usually no cruise at all.
So I called my dealer and they gave me a different sequence.
1. With engine at idle, accelerate with the treadle pedal.
2. Engage cruise control lever.
3. Then use the throttle to set the desired speed.
This works on the tractor, but doesn't make sense to me since I can't know what the tractor speed will be once I throttle up to 540 PTO shaft speed. Is this the way the cruise control is supposed to work or am I missing something?
