Landpride 3rd function valve issue
EKRanch
Idaho
Have a LP 3rd function valve. One of the buttons keeps blowing fuse when depressed.
I’ve checked all wiring. Any ideas?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
396
145
CNY
How have you checked the wiring? Did you check for continuity to ground with a multimeter? Have you checked the resistance of the coil on the valve?
In order to blow a fuse you most likely have a short to ground or excessive current draw through the coil.
B737
LX3310
Jun 9, 2019
2,024
2,200
which kit, which tractor?
it's possible one of the screws that hold the handle on have pierced the wire from said button.
