Land pride 1260 maintenance
Otisdog
L 3800, LP RCR 1260 cutter, LP LP FTP 500 spreader, LA 524 loader
May 5, 2013
24
Decatur, Alabama
I just performed first 8 hour service on my LP 1260 Cutter. Gauge wheel grease point calls for pumping grease until it exits from the relief port. I can't find a relief port. Wondering if this is a manual glitch or if it got left off when mine was built. Looking for input. Thanks
kubotasam
Apr 26, 2010
1,204
128
Alfred Maine
Unless this is something totally new that I don't understand. I think all it means is you add grease until it comes out the top and bottom of where the shaft goes through the bushing.
Otisdog
May 5, 2013
24
Decatur, Alabama
On the shaft I pumped grease until it came out. the second grease port I think serves the wheel bearings/bushings. That is the one that said to look for the relief port.
Otisdog
May 5, 2013
24
Decatur, Alabama
I pumped grease for a while on the bearings but didn't see it come out anywhere.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
The hubs where the bearings are hold alot more grease than you would think. If it was the first time greasing them each one will take several oz's to fill. After that it shouldn't take no where near as much to keep them filled.
1,412
There are "grease relief ports" that are available for places that you do not want to build up pressure with grease pumping.
This link is to Alemite's
http://www.alemite.com/catalog/details.aspx?identifier=fittings_relief
I personally would not think that one of these would be installed on a piece of farm equipment unless there are some grease seals at the end of the axle that could be forced out of the housing.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
This...................
kubotasam
Apr 26, 2010
1,204
128
Alfred Maine
I had never seen such a device. I love it when people on this site share their knowledge. One person might not know the answer but when we get together we are almost unstoppable.
